Kirby G3 tech drive question...
funvacfan
Canada
I replaced the handle spring a couple of weeks ago and have been using it a few times since. What I can't fiqure out is whether the tech drive should assist when you pull back as well as when you push forward?
Right now it only assists when I push forward. I flipped it on it's back and observed, and indeed, only when pushed.
Have I installed the handle spring incorrectly? I got it from 007kirbyman, so I know it's not the part! Kirby had redesigned the part, so it didn't look like the original, but I thought that I placed the "forked" part correctly over the "nub".
Any ideas, or parts diagrams before I take it apart again?
Guy
Make sure you have the "fork" placed in between the grooves on the pivot spring. The transmission should work both forwards and backwards.
