matt8808
As some of you may remember I recently had to install a new power switch on my Sentria II.
While I had the machine in bits I also changed the fan as the old one had some slight damage.
All genuine parts... full fan kit with the new belt shaft and little washers and seals ect.
My question is this....
When I've fitted the new fan I've clamped the rear of the motor shaft at the back of the motor with a small spanner, slotted a large nail through the hole on the belt shaft and tightened the new fan on as tight as it will go by hand.
Is this correct?
I've not used the machine since as it is still in my bad books and I'm content with my Miele C3 Cat Dog... but I just wanted to be sure I haven't done anything wrong for when I do decide to take the Kirby for a spin again.
Reason I ask is that I'm sure I once read somewhere online to only tighten it finger tight.... something to do with it being tight causing damage??
Oh and James if you're reading this.... I'd of asked you about this but I no longer have Facebook and have managed to loose your email address!
Is this correct?
