Hope this isn't against the rules....I also posted this in the supermarket area.
I was given a Kirby Classic III. When I turned it on dust blew everywhere. I took it to a repair shop to have it fixed and the repairman put in new bearings and cleaned(?) the bag and roller. When I picked it up I asked if the light worked and he said yes. I told him that I brought it in because it blew dust everywhere when I turned it on. He answered and said that he vacuumed the bag. I assumed that meant that he fixed the problem.. $99.95 later I get it home and today I tried to use it.... The light still doesn't work and dust STILL blows everywhere. I emptied out the bag and when I took it apart I found a gasket where the Sani Em-tor attaches to the body of the motor and the gasket is falling apart. The bottom of the red plastic at the bottom of the Sani Em-tor has what looks like a fuzzy gasket. It's compressed and it doesn't look like it's sealing. There is dirt and lint coming from the "seam" next to the "toe-touch"nozzle adjustment. (I'd call that a height adjustment switch.) Dust also blows out around the bottom of the bag.
I'm SO frustrated! I was so excited to finally get a Kirby and then the repairman didn't really fix it! I'm trying to find the gasket for the Sani Em-tor online and and haven't had any luck. I also have no idea how to stop dirt from coming out at the "seam" and around the bottom of the bag.
I did vacuum with it tonight in spite of the dust and it STILL works better than any other vacuum I've had. It picked up all the little threads and sock fuzzies and even brought up the nap on my very old carpet.
I really want to fix this vac. Does anyone have any suggestions? Does anyone have the parts I need or can you tell me where to buy them? Is this a do it myself job? I'm not particularly handy but am willing to try to fix it. Do you think I should I stop spending money on this vac cause it's a lost cause?
Thank you in advance for any help or advice you can give.
[ATTACH=full]80411[/ATTACH]
[ATTACH=full]80412[/ATTACH]
[ATTACH=full]80413[/ATTACH]
[ATTACH=full]80414[/ATTACH]
[ATTACH=full]80415[/ATTACH]
