Kirby classic 3 maintenance and restoration questions
jgarvey
Wrightstown, NJ
Hello everyone!
New to me classic 3 that doesn’t seem to have the right bag setup. It doesn’t secure to the hand pole with the rubber topper and it definitely doesn’t balloon at all. It does clean something serious though!! What do I need to make it right? And does anyone have the required parts?
Also, how on earth do I remove the headlight bulb? It feels like it neither twists or pulls out. Also, are there any led options as a replacement?
Thanks in advance!
JGarvey
Joe,
Your Classic III has the indeed infamous F&G conversion kit on it. It was not good at all, as the design of it tended to cut off incoming suction noticeably.
You need a proper Sani Emtor and bag, which would have looked like this at the time your machine was made.
To remove the bulb, unscrew the lens, push the bulb, and twist counterclockwise while pushing on it. It could be different with the Classic III, but it is like that with both my 1cr and Heritage II.
Hoover300
The Classic 1CR light bulb is not the same as those for models Classic Omega 1CB to Legend II.
Whereas the 1CR's light bulb is 120 volt, twin-contact, the light bulb for models 1CB to Legend II's is 12 volt and single-contact.
In either case, it must be correctly assembled or it may not light when the cleaner runs.
Yes, push in slightly and twist CCW to remove.
This 12V bulb can be replaced with an 1156 automotive back-up bulb available at many local retailers.
Yes
I know a few. There great you would love them.
HHF LED Bulbs Lamps, Dimmable BA15D 5W AC 220-240V (1PCS) 80 LED 4014 SMD 400-500 LM Warm White Cool White LED Silica Gel Lamp (Color : Warm White) https://www.amazon.com/dp/B07DBP7NWZ/ref=cm_sw_r_sms_apa_i_mYj5DbVYC25HE
Try this i have a few there good. You go too cheap silicone gets ruined when you try to twist bulb in or out.
I have a link of ones from China but you have to wait a while.
thats cool
when i was 5 i wrote a letter to santa in red crayon to bring me a "big red kirby"(didnt know the model names yet)
