Kirby Accessories are kinda weird
amtraksebo1997
Vacmasterthegreats basement
This is just kind of an opinion piece, but I thought I'd share my thoughts on certain Kirby Accessories.
There are certain accessories and functions that Kirby pushed that are kind of weird/unfitting for a household vacuum cleaner.
1. The Turbo Accessory kit. It seems like a neat machine, but I can't picture myself using it with a Kirby as an actual sander. I'd probably leave that job to a Shop Vac. Everything else (buffer, scourer, and massager) I can more-or-less see someone using with a Kirby. Although, I'm not sure I'd want to listen to the deafening sound of the machine in tool mode on top of the Turbo Accessory. On the topic, the massage cup is also a little strange, as I wouldn't want to use it on my hair or body with how dirty the machine itself is from use. My dog might enjoy it, though!
2. The Handi-Butler. Again, this doesn't seem like a tool that's appropriate for a household vacuum. Reason being that I wouldn't want it to get all dirtied up from shop dust while I'm working. Maybe Kirby should've done what Electrolux did and made a separate wet/dry vacuum for all of these power tool accessories. Maybe they could've even made a carpet extraction system for it, similar to a Vax or Bissell Big Green canister.
3.The handheld mode. I can't really justify a reason to use this with a G Series. Maybe it was easier and more practical to use on a pre Tech-Drive machine, but I've tried using it on my stairs and my bed, and it wasn't great for either of them. You can kind of make the argument that you'll get better agitation with the power nozzle on stairs, but I'd rather use the Zipp Brush with the hose. That's another thing, It seems kind of unsanitary to use the power nozzle that goes on your dirty floors and carpets. Again, I'd rather just use the Zipp Brush for it (not that it's completely sanitary to do it that way either, but it's slightly more so). Thus, the only use I can see using the handheld handle is for using the machine with the hose.
4. The portable sprayer/blower. It's not that this addition is weird or next to useless, it's just that execution on it is not the greatest. This is because when you use the hose in blower mode, any dust that is caked around the inside of the hose and fan chamber will get blown into the air. That kind of doesn't matter if you're inflating something, but using the sprayer or otherwise blowing stuff with just the hose indoors is gonna spew a bunch of dust back into the air. My advice is to get a 2nd hose to only use with the blower attachments, which is probably something that Kirby should've included to begin with, along with some sort of filter for it to catch any dust in the air before it's blown out.
AmtrakSebo1997
I do have to agree with you about #3 and #4, except that I want to say the same with regards to both of these about the power cord, because with the long handle you risk breaking the cord hooks at the bottom of the rear insert (for models Classic Omega 1-CB up to the Ultimate G).
I find the inflator deflator tool weird because why would you design a tool that could damage your machine if not used correctly
Hi Amtrak I think it’s because of the small opening it can cause the Kirby to overheat and iv also heard that after a minute you have to turn it off to let it cool down and if not used correctly it can cause damage to the fan
the Multi- surface shamppoo system
Although its an ok idea, you would still need some sort of mopping device for your hard floors. Personally I wouldn't want to use a kirby to mop my hard surface floors and its like I said, you would still need to have some sort of mopping device, espescially for those hard to reach places, rather it be under the bed or in certain parts of the bathroom. Also just using the kirby on hard floors in general unbarebly loud. I sure wouldn't want to mop my floors with something that loud and then have to use something else for the hard to reach places.
Another accessory that I think is kind of a joke is the zippbrush. I think this simply because its not sucking up the dirt and debris, its just loosening up and making the tool itself dirty, thus having to spend time cleaning it afterwards.
I also have to agree that the handheld mode is a joke as well especially given the other alternatives out on the market, that being canisters and stick vacs which have less weight and some if not most, are cordless.
I dont think anyone these days uses a portable foam shampoo function anymore (referring to the portable shampooer). Now and days most people that I know of would just use an extraction type portable cleaner, like bissell or hoovers.
One thing we all have to realize is that kirby as a company is still functioning like this is the late 1900s. I mean this current platform and its functions may have been good for what it was back then, but now with new and better alternatives its like they kind of given up and can't beat its competitors, thus why we have the past two models be the exact same color, just with a different accent color.
Sander
The sander is great. If your sanding wood you worry about all the sawdust. The sawdust. The vacuum sucks up the saw dust so they doesn't go everywhere.
The blower I heard melts fans.
The old handi butlers are nice because there like a flex shaft. It can be used like a dremmel tool to anything under the sun.
The multi surface cleaner you don't have to use something after.
If you know what your doing all the tools have very practical uses.
Every Kirby came with accessories.
They're nice additions if u know limitations and how to use them.
juju93 wrote: Another accessory that I think is kind of a joke is the zippbrush. I think this simply because its not sucking up the dirt and debris, its just loosening up and making the tool itself dirty, thus having to spend time cleaning it afterwards.
I reply: I agree. The Turbo Brush offered with the Heritage 1HD is far superior. The Zipp Brush makes little sense, except for scrubbing spots that have previously been sprayed with the shampoo sprayer, but you still need to vacuum up the dry shampoo, making it a three-step process.
Honestly, I have been fascinated with Kirbys since I saw a Classic Omega demonstrated in our living room when I was about nine or ten years old. Kirby did their best to stretch the definition of a vacuum cleaner as far as they could, making it a versatile home maintenance system. Understandably, some accessories and functions were more successful than others. I'm glad I have a bunch of them, I'll continue using them as long as bags and belts are available.
They definitely have some weird attachments, I never use them as a result. I think they made a mistake getting rid of the original turbo brush which is technically a Vacuflo Rug Rat that you can still buy today. Even their Vacuette hand vac does a better job than the Zipp Brush, I own two myself but one of them is a Kenmore.
Keep in mind that some of the attachments, like the sprayer, handibutler and sander came out before these power tools became commonplace in the home.
Many were gimmicks but some worked pretty well.
Nowdays most are a bit out of place. Space seems to be at a premium today as well. Very few wants to have a Kirby upright standing right where they are sanding or grinding or spraying. And I want to keep my indoor Kirby clean!
The inflater tool severely limited airflow.
A vacuum fan is like an air compressor. Compressing air causes lots of friction and the fan takes all that heat. Normal use as a vacuum causes the large airflow to cool the fan. This is why the air coming from the bag is warm.
Limiting the airflow will cause the plastic fans to warp or melt and grenade if left on long enough. I had a few that met that demise...
I do hope kirby is listening to our needs and wants and will some day address these issues and concerns with a true new model (new platform). Speaking of new models, and not to get off topic, I'm ready for Rexair to come out with a new model.The SRX came out back in 2019 so its going to turn 6 this year, so its time for the next thing from them as well as some new or updated accessories, besides the power nozzle.
KirbyG6, JuJu93, and others.
-That's what I remember hearing about with the inflator/deflator tool. Maybe if they drilled a few extra relief holes in the attachment, that'd put less strain on the motor. I haven't used that tool for anything outside of trying to clean my desk and keyboard as Kirby said I could in their instructional videos, to little success. That's why I have one of those micro-attachment kits now, and it works much better for that job.
-Kirby actually does make a mop-head, and the new rendition of the CSS can be used as a mop apparently.
-As I said before, the sander and Handi-Butler are probably good attachments, I just don't like the idea of using your household vacuum to power them. Those are probably best left for Shop-Vacs, similar to how lots of power tools have hose-ports so that any dust kicked up by them can be sucked up.
-Personally, I think the Zippbrush is an alright attachment. It seems to agitate alright. Additionally, I think Kirby made the switch to it with the Heritage II because Kirbys (at least the Generation Series) can't spin up traditional turbo tools well. I could be totally wrong, though.
-Kirby is definitely dated in a lot of ways, but I think they want to keep it that way. Maybe for nostalgia's sake, maybe for novelty's sake, IDK. That probably explains the wacky lineup of accessories. I hope in the coming years Kirby finally stops just re-selling the G3 with a new color-scheme/handle/optional accessory, and actually does some innovation with their products. More importantly, I hope they reshape their business model so that their salespeople don't have to resort to harassing the elderly and lower class, as these machines are simply not suitable for the former group. MLMs are kinda cringe ngl.
I'm ready for something new from rexair in terms of a new system or new optional accessory. As far as kirby goes, I hope by 2030 they'll have something truly new and innovative.
With the problems of melting-deforming fans-Kirby shoudl GO BACK to the METAL fans-No melting or deforming problems with those-esp if you should use the Kirby as a "centrifical compressor"as with the inflator-deflator tool on the blower mode.And yet ANOTHER Kirby came to the vac shop here with a deformed fan-user allowed the bag to get too full.This will deform the fan.
Metal
They won't go back to metal. Imagine what hot metal would do.
They could make a third speed just for inflating.
I agree about the metal fans, I've seen how much it improves the performance. From my understanding and I'll say it again, Kirby won't release a new model unless it's proven to be better than it's predecessor. I'm sure by now Rexair has regretted not taking Kirby's example. I've read somewhere online from a Rainbow rep admitting Rexair made a mistake releasing the SRX model, it clearly wasn't better than it's predecessor. If I was Rexair, I'd go back to making the E2 in a different color until when or if they come out with something that's proven to be better. They already brought the old powerhead back. But regardless of what, we could see the end of Rainbow soon and I've also read this last year didn't do too well sales wise so that didn't help out. Market has changed, sale methods are different, and quite a bit of competition. I'd definitely take a Sirena over any new Rainbow. And if Royal was still around, I'd also take one over any new Kirby. Also if I was Kirby, I'd bring back Royal from TTI as their Comvac line.
