Kirby 560 running backwards!?
kirbyvacsandmor
Active member
WY US
my kirby 560 is running backwards the shaft is spinning to the right instead of the left what went wrong when i took it apart?
Thanks,
Lars
If it were a DC motor, I'd say you connected the wires backwards but that shouldn't happen with an AC motor as polarity isn't constant. Still, you might try reversing the wires to the motor and see if that fixes it.
I tried that and it slowed down the motor alot could that also be that one of the connectors is half broken? But now it is running the right way.
Thanks,
Lars
Every Kirby...
I ever saw, the fan and motor shaft turns clockwise.  The motor shaft and fan should be spinning to the right when viewed from the front of the motor.
Well, Like I said, I have never seen any Kirby that runs counter-clockwise. EVER! They all run Clockwise!
So turn it on and see if there is any suction thru the hose on the front or if the blower function works with the hose connected to the exhaust port. If the motor is running backward as you say, then there will be only a slight air movement through the hose when connected to the front of the machine.
p.s. If the motor is running backward, then the belt won't stay on. So if the belt stays on the motor shaft when the motor is running, then the motor is running in the correct direction.
