Kirby 512 Fan
fantomfan
Rochester, New York
Hi all,
I have my Kirby 512 in for servicing, and my vac shop is having trouble finding a new fan for it. (The previous owners busted it.) They are not sure where one would be available. I have a hard time believing that there's NO new fan made for a 512 out there. Any thoughts to where one could be found? Thank You! -Mitchell
119078A Fan Asy 505/515 Kit
this kit will have the white Amodel fan, a longer spacer (which takes the place of the back of the metal fan going into the front of the bearing plate) a metal washer for the front of the fan and a new belt spindle.
Any Kirby shop (distributor or service shop) can order this from Kirby. I just ordered another one for one of my Kirbys. It usually takes about 2 days from the time you order it till the shop has it.
Make sure you order this number with an A at the end, if you order it with and S at the end you will get the 516 thru Legend II kit which has a shorter spacer and won't work with your model.
If you try to find a metal fan it will most likely be a used one as they haven't made them in years, unless you're lucky enough to run across NOS in a dealers back room.
Ok, the shop cannot get a fan.
I am going to order the part myself. I am checking vac parts warehouse. I do see that it's the correct number. Will I need any other parts, if i'm switching from a metal to a plastic fan?
Nope, You don't need to order anything extra, all that you need comes with the fan.
That's odd that the vac shop can't get that for you. Steel City sells them as well as a number of Vac parts companies.
My shop doesn't deal with Kirby
The owner (whom I have known for 4 years now) told me that they don't deal with the Kirby distributors. Their own distributors kept giving him the newer style fan. That's ok though, thank you for the info. I'll order it tonight!
I am fed up with this thing!
I just got the part today, and it's wrong. They sent me the newer fan, the 119078S, for 516 and up. I needed the 119078A and the form that came in the package had the CORRECT fan #. I'm not going to return it. It's too much of a hassle to ship back. It will be a waste of $$$$ for me to pay to ship it back and not be reimbursed for shipping. I'm going to keep it just in case I'll ever need it for my Sanitronic VII or Heritage II. In that respect, it wasn't a total mistake. I'm going to go out to a Kirby specialist in my area (NOT the mean one) and I'll try to get a fan there. Not a big deal, I know something will turn up eventually.
