DesertTortoise
- Joined
- Jun 6, 2014
- Messages
- 1,189
Another busy night in the Kenmore High Desert Restoration Facility. This one is a more straightforward job, disassemble, clean, easy polish and reassemble. This is a suction unit only. Future plans call for the installation of the necessary two wire connector at the swivel, and a possible heart/lung transplant at a later date with the motor currently residing in the Avocado Bomber. Tomorrow night we will test fit an identical sized motor from a 4.5 undergoing a more extensive rework. The necessary rubber motor mount is on order. The support plate seems to be common across the line. We will also use the opportunity to test fit some different cord reels to see what swaps to what.
Some of the staff are pretty lazy however, and require more or less constant supervision.
Some of the images are taken to use as reference for reassembly, particularly those of the orientation of the on/off switch and what wires go where on the two terminals.
