Kenmore canister hose
kloveland
Tulsa
Just found this Kenmore canister at an estate sale today. Can a replacement hose be bought for this? Had a Kenmore canister awhile back but it was in such nice shape that I sold it. Plan on keeping this one. The hose has three pins that connect to the canister instead of two.
It's model number: 116.2745582
Nice find!
I don't believe that hose is available any longer. You may be able to get replacement tubing for the hose and reuse the ends. Or I think maybe a newer closed loop handle hose may work too. Some of them had both the variable speed control as well as the Off/Floor/Carpet selector like your hose does, and would use a 3 pin connection.
You'll want that replacement hose, as it is repairable with a new hose section. The older style hose has molded ends that couldn't be removed. Once the hose started tearing, it couldn't be cut down or replaced seperately.
