Reply to thread
Yeah that's pretty much the same way I used to do it before I purchased the tool, he does though make it look very easy in that video by only adding a small amount of tension on it, Also I've found by anchoring the motor shell helps too so it's not moving about whilst you do this, I usually just screw it down to me worktop using the bottom screw hole. Your'e idea seems good even if you don't add the full tension on the spring it might just stop the handle flying back at you.
