I have a Kenmore Progressive canister that's variable speed. Usually I keep it on the lowest setting for doing dusting or hard floor vacuuming, because it seems to pick up just fine on that speed.
I usually use the higher speed for when I use the power nozzle on carpets or sometimes in the car.
My thinking is it's probably better on the bearings since it's running slower, especially with these newer single stage motors, that I hear run higher RPMs than the older Ametek 2 stages.
On the other hand, I'm wondering if maybe the motor is actually running hotter due to less air flowing.
I sort of do the same thing with my Kenmore Progressive upright too which has a 3 speed motor, although sometimes I use it on Inteli-clean which auto-shifts the speeds depending on the amount of dirt being sensed.
