Is it bad to use a antique vacuum as a evey day cleaner?
Anyway back to the thread at hand, I use my vacuums but I do plug them into a variac just as a precaution so if they were made to run on 100 to 110 I set the voltage at 110, if they were made for 115 I set the voltage for 115, if the vacuum is new it can handle 126 V AC. I just don't want to burn out the motors with excess voltage.
Here's a picture of my Hoover Special model 102
I had my 450
I had my hoover 450 on a vareac for the first cupel runs until the brushes wore in but should I keep runing it on a. Vareac because it is rated at 100-155-105-120volts ac or DC and I'm looking for a dust tool set for it ?
As for<span style="text-decoration: underline;"> the smells</span> of older appliances, I don't know exactly what it is but I suspect it was the type of oils they were using.  I've noticed it particularly on motors and motor windings. Everything has some type of oil or coating on it.  I think in the 70s they started adding a subtle scent to the oils.  Even plastic items will have a form of oil on them.
I wouldn't describe it as musty but it's interesting that letting it air out, perhaps letting it sit in the sun, helps to dissipate it.
A relative worked at a community museum and they were always getting retro stuff donated.  A lot of stuff from the 40s and 50s.  They had this jukebox from that time period someone donated and it had fabric wrapped wire inside.
She asked if I'd look at it to see if it would work.
I wanted to look inside before plugging it in.  Make sure there was no blaring problems that could easily be avoided.  I took the back off and there was the smell.  There was also a few mouse nests in the bottom which is a different smell.  Anyway, it looked OK, but sure enough, plugged it in and some of the wires stapled to the side started melting off the fabric covering with little sparks as it went along.  It didn't even blow the fuse.  I quickly unplugged it.  I didn't want to ruin it.
I can still picture and smell my mother's 1950s/60s Pencrest sewing machine and the smell.
My great grandmothers automatic ironer from the 50s and opening it up and there was the smell.
bikerboy-- "Anyway back to the thread at hand..." Where did you go? No one else here left.  Did you have a mental lapse?
And for the three mooks (The three stooges) here who are apparently immune to good sense health advice and feel the need to protest in the most predictable way, remember, you can go out and ruin your health all you want.  My words aren't apparently meant for you.
You may not be concerned about helping other members who have concerns and you may not care about your health, but I care.
Just as I have before, I will continue to warn innocents of these legitimate concerns.
If you don't like that than <span style="text-decoration: underline;">YOU</span> have more than one problem.
"A phobia of asbestos"   ?
Yes, you should.  And lead paint, and radioactive paint, and walking in traffic, and drinking toxic chemicals.... and so on.
If you don't than seriously, there is something wrong with you.
Collecting artifacts from the past is fine when proper precautions are taken to protect yourself from known defects with them.
https://www.cnn.com/style/article/radium-girls-radioactive-paint/index.html
Hey bikerray, how does your old Hoover do on those tiny throw rugs? I have been looking for a good old vacuum that can clean them without eating them, aqnd having just bought my second 700 series Hoover I never really seen many people cleaning with them in day to day life. Pretty much every modern vacuum I have is a PITA to vacuum small mats and rugs.
I have a bunch of Electroluxes too but none of them are operational right now.
Well if they work like the Kirbys and Royals I'm familiar with they should do fine. My Royal uprights do a awesome job deep cleaning and grooming my low pile carpet. Small throw rugs might be a problem as it would try to suck them up but being old machines they might not have the suction power some of the newer vacs I run. I have a 12 amp Royal and that thing is a loud beast that tries to pick up everything. The lower amp Stark/Royal 5700 is much quieter and does a great job without being so quick to grab everything.The others here should be able to give you a users perspective on how well the oldies actually do.
Yeah I seen that the Kirby Ultimate Diamond Edition I do believe has a 2 stage motor that has a slow speed mode for cleaning throw rugs - but I have not found one cheap yet so I've been trying to get information on which of my vintage vacs can do throw rugs good, as I kind of have to stand in a tripod pose with my foot on each end of the rug to hold it down, and then vacuum from a sideways standing position. lol
The Kirby only has one fan it's not a 2 stage
Kirby has had a High Low speed ever since the Kirby Dual Sanitronic 50.
The Kirby Ultimate Diamond Edition has a switch next to the handle spring that divides the motor speed again giving you four speeds.
I have one small rug that I have to hold down when I vacuum, all the other rugs have pads underneath that hold them in place.
