Reply to thread
I HAVE THE SAME MACHINE!
And I have the same problem!
It's definitely not the best water/filter design out there. It needs regular water changes to avoid this. I'm not talking half hourly changes. More like five minutely ones. As the more debris that are in the water, the higher the bubbles go, following more water passing through the fan.
There must also be ridges in the motor housing as it holds water. It may appear that it has stopped it's incontinent behaviour but if you are to lift off the motor housing and tip it you end up with a wet floor.
I hope this makes some sense. I'm on my phone. In meeting..
