In Search Of Hose for Constellation 858
moonlady
Ohio
My Hoover Constellation 858 hose finally gave up the ghost and the local vacuum shop isn't able to repair it, so looking for a replacement. Thanks.
Update
I asked about the central vac hose, but he said they were either too big or too small. So, I brought it home and did a little surgery. Turned out there was a sewing needle wedged across the tube and a bunch of stuff got jammed around it. I still need to get the hose replaced, but hopefully it will do the job until I can get it to a different shop. Thanks!
hose
if you still cant find someone to make up a new hoe for you. I can help you out. you could send me the old ends and i can make you a new hose. I can also service your vacuum motor. I also have bags and filters and parts for Hoover constellations.
C.S. Vacuum
124 Madison st.
Oneida NY 13421
315-363-9083 leave message and i will call you back.
you can txt also
