human
So I've never been particularly impressed with my Sanitaire SC686's ability to clean Persian rugs and after due consideration, decided the brush roll might be in need of new strips, even though they didn't look too bad to my untrained eye.
So I ordered two pairs of strips, which came in today. The bristles are noticeably stiffer and maybe 3mm longer than the ones I took out. One thing I don't understand is why they sell the strips in pairs—one long and one short—when you really need two of each. Installing them was more of a challenge than I expected. The strips were slightly wider than the channels into which they fit on the brush roll and putting them in required a bit of trimming from the widest part of the strips' plastic base, along with copious amounts of silicone spray. I also learned along way that because the strips are straight and the channels follow a somewhat spiral path, you have to twist them hard in a clockwise direction to get them to go. Each of the four strips was a little easier than the one before it, so I must have been improving my technique along the way.
Once I got everything buttoned up, I moved some chairs out of the way and vacuumed the Persian rug in my dining room. The improvement in performance was like night and day. Still, after running for two, maybe three minutes, there was an unmistakable odor of overheated rubber, presumably from the belt, so while it's definitely much better, it's still not perfect.
