How to??
beerad
Beautiful Vancouver BC
I am trying to remove the motor hood of my Hoover UR model 586...How doo I do this?? Also... I have no power as soon as I plug the handle in the base. When I remove the handle and plug the vacuum in from the plug right on the base it works? Maybe a switch?
Thanks.
Brad,
To remove the hood flip the vacuum over and there are two screws one on each side that needs removed, the screws are behind the front wheels.
Asfor the power issue, either the switch is bad as you stated, or it is possible that one of the wires are disconnected from the switch.
Sam
