How to tell a Kirby model 508 bag from 509 and 510 bags ?
odavid123
Los Angeles ca
At one point the 508 bag was made with the same material as with the 505 . Then it introduced what we are familiar with for the 509-512 bags but there is a difference. Can someone here guess what it is ?
Clue : it has to do with slider and cuff ..
There were
2 versions of the 508
1 version of the 509
1 version of the 510-512
Let he know the difference between all the versions …
2
Versions
Adam mercer has a white duvetyne bag with the same print as the 505.
I'm guessing your looking for the 505 print 508 bag also has the 505 shape.
The second 508 is tan with kirby writing in the center with the center of the bag having the logo and stripes are paralell 3 inches apart from tje botyo. Of the bag to the top.long the bottom of the bag has an inch overlap the fold in and sew the bag spring in. There is 5/8 of an inch extra material left inside. The bag stitching is where it's sewn together 1/2-5/8" overlap.
The early bag might be a different height and shape.
The 509 has color added to the stripes.
The font changes too.
I'm tired but hopefully this cfos makes sense. Ill try to proof read.
The 510 has different color lettering. I've seen blue 508-512 bags but I think they were NOS kirby replacement before they started using variations of the 513 as a replacement bag.
I
Have a 508 corduroy bag that's tan in color and it's original. I also have a 511 that's tan and it's and they both came from the factory like that. They could be faded but the lettering is in great shape so idk.
The dye they used on those bags was somewhat defective , especially on models 509-517.
Even when kept away from the light they still fade. It happens almost exclusively with the gray corduroy material .
I’m sure your bags are in great shape but like all of our bags no matter how much you take care of them they will fade .
I learned a trick from Charles , if you have a bag that’s in good condition put it on a hanger in a closet it will fade less.
So to answer this question I will add pictures here.
The very first version of the Model 508 ( same design as with the 505 ,gray with silver and red print) had a front opening slide cuff with a button to fasten it in front .
second version introduced the more familiar 509-512 gray bag but it still had the opening in front please see image.
Model 509 had the cuff cloth opening in the back of the bag
both bag sliders had the same 8 type chain as with the 505
And finally the 510 introduced the ball chain slide
let me know if you have any questions
as always you are welcome to visit my kirby site for more info www.collectingdust.com
Bag
Adam mercer and yourself are the only bags I've seen Luke the 505.
Take a look at the attachments. That looks like an oem kirby 505 bag.
I made it identical to the 505 bag. White duvetyne is a very bright white.
It's not a stretch to think the only 2 508 bags were made by someone.
I guarantee I could duplicate the bag and without knowing there is no wY you could tell someone made it.
In short there's only 1 508 bag the other was made. 2 bags vs hundreds of thousands of 508 bags the probably there was no prototype is higher than 99% supporting there's no prototype.
The 511 bag immaculate condition I'm sorry but the entire bag is the same color throughout. This means it's not faded or sun damaged.
The faded bag theory kind of loses credibility when I produce an original immaculate condition light tan is the original bag color.
The accuracy of your website has flaws and the proofs in the putting.
Hi 👋
Of course my site has flaws I never said it was perfect :)
In regards to the 508 , although I it was produced for one year it had many updates .
I will post more pics on my site of an all original in the box in the coming weeks . As for the bag , most bags out there are from models 509 on .. the bags that are 508 original are same design as the 509 but with the slide cloth cover opening in the front .
The wide 508 bag that looks like a 505 is indeed very rare, the one on my site says it’s a replica .
As for the screenshot you attached of info on the c models I disagree with as I do have multiple C models and R models and the info on the 2C and 3C are incorrect , I don’t know if you attached it just to show the bags or to correct me on the C models .
I admit that I will have to keep updating information as it comes in , I have already made some changes
Well I do try to be as accurate as can be . when I decided to share my collection with everyone I knew there would be some that would disagree with me , which is perfectly fine and I welcome positive criticism.
Is my website flawed ?! it’s not perfect I agree . I welcome any new information or amendments as long as there is solid proof to them .
Ty
David
More 508 vs 509
As you can see from the image below the 509 vs 508 there are 2 very clear diffrences .
unlike the 509 the dashed lines on the 508 go all the way to the bottom of the bag without stopping before the tube spring ,there is no space.
same goes for the top ,because the opening of the cloth slide cover is in the front on the 508 the dashed lines goes all the way to the top under the flap. which is the second obvious difference.(front stitched cloth cover)
as for he replica of the 1st 508 bag on the website it's just that and if you look at the bags page it clearly states replica . it does exist tough and i hope to one day update the site with it.
now in regards to white bags or the tan bags I guarantee you they are really just faded bc of the type of dye used. The original gray on the 508 is a greenish dark gray but with model 509 on it was just gray.
I'm firm on this and I agree to disagree.
