Reply to thread
I have worked on a few of these machines try checking the nut that tightens the fan to the motor shaft.I found out the nut has no locking washer & the nut comes loose over time.I also tighten the nut down with lock tight the fix seems to be holding out so far.I hope this helps you out?
