Hey Guys!
I have a Hoover floor polisher/shampooer model F4300. The problem is when I fill the solution tank it either leaks or the solution will not dispense. There is a small rubber gasket/washer inside the small screw cap at the bottom of the tank where the trigger releases the solution. I replaced this rubber gasket/washer but I am not quite sure how it is supposed to sit inside the screw cap. I am not sure if it is supposed to sit without the stem and metal nipple piercing the hole or not and in which direction the washer/gasket is supposed sit. It is sort of pyramidal in shape.
Anyone have any experience with these tanks?
Thanks!
Thanks!
