wyaple
Please chime in on this...
A few weeks ago, I nabbed a U4007 at a thrift shop and proceeded to restore it as best as possible. I did discover that the upper motor bearing was significantly worn so with the help of Andy R. (vacuumlad1650), I replaced that part. I also discovered that the lower bearing was partially stuck. It turned poorly, so I proceeded to do what I think most experts here would say was EXACTLY the wrong thing to do.
I used the blue can of 3-in-one oil to soak both the top and bottom of the lower motor bearing.
BEFORE all you experts scream at me, let me tell you the issue I was facing. When I closely examined the lower bearing, I was going to attempt to squeeze in some Mobil EMB (electric motor bearing) grease, which is specifically rated for high speed electric motor shafts. BUT, I was shocked that I found FELT WASHERS perfectly fitted to both the top and bottom of the lower bearing. I used a toothpick to partially ease out a piece of the material just to verify I wasn't losing my mind. Welp, my U4007 has felt washers in fairly good condition on the top and bottom of the bearing, so without completely removing them, there is no way to force in any thicker grease as I've read your supposed to do.
After completely freeing up the lower bearing with blue can 3-in-one, I cautiously ran the machine and it sounds....PERFECT! Spin up and spin down sound as good if not better than any YouTube video I have ever seen and I've searched through all the convertible videos I can find.
Now, I'm not saying I've done the "right" thing, but I have two lingering questions:
1) Has anyone ever seen felt washers on the lower bearing and
2) how often should I re-lubricate this lower bearing with 3-in-one oil?
My long term plan is to use this machine about 30 minutes a month or around 6 hours per year. Light but consistent usage I suppose.
Bill
Bill
