Hoover Concept One PowerDrive (Model U3109) Help
dwl93
IL
So as you may already know the handle support piece on my Concept One cracked and after gluing it, it cracked again, so instead of gluing it, I bought a full handle of off ebay for $25 (I know that's a bit pricy, but I didn't want to pass it up either) to get the handle support piece out of it. However, I don't know how to get it out, so I was wondering if any of you knew how to remove them. This handle support piece is the only thing I need to make this concept one perfect. Below is the photo from the ebay listing and the other photo is a picture I took after getting it.
Here is something....
First, take the handle off, then on the back side of the handle is a screw, unscrew that, there is a little rod that controls the Power Drive then take the whole handle off. Take the back side (where the bag is) and take the 2 screws supporting the handle. Next, there is a screw on the front of the handle that holds the handle grip and take that out.
Hope that helped.
Logan H.
