Hoover Compact S3708
beko1987
Stokenchurch, United Kingdom
19 years old, not quite vintage yet!
From Hoover Compact S3708
First issue, the hosewas split.
However, unlike its more modular predecessor, the whole thing doesnt strip down nicely and re-thread on, its all one moulded thing. So the hose is glued into the machine end, with some tape around it slightly for added measure. Anyone know if you can get the machine ends for these still?
Anyway, it was very dusty so I got to work
Very late!
Very nice
The accountants had obviously stolen the lint pickers by this stage
Although, what's this?
Anyone got a nicer version of this for sale?!
One of the tabs has broken off the tray too sadly
Had no smell at all anymore! Surprised it lasted so long though without being binned!
I'm sure I;ve got some compact/aria filters somewhere. Hope so!
This is a shame. The whole thing is sealed and currently stuck fast with fluff. Hoping getting it wet and putting another vac to the tiny hole gets it out
Undid the screws and the motor housing came off
My 1997 french car uses the same connectors on the dashboard as this 1997 french Hoover! These have fared better...
Yummy
Came up ok with a hose down with brake cleaner!
Stripped
I had to open a connector and pop a wire out
to get the bumper/chassis seal off
Happy to see the power outlet still featured this late on!
I couldnt get the rear wheels off though, looked like it would break if I kept trying so left them be
So all unpicked, and waiting to be washed.
Screw card has never been so empty! All just clips together!
The palstic extension poles were both cracked at the top too. One is glued up, I'l clean that off and work out the best finish to hide the glue mark, and do the other pipe. Floor tool is almost mint! Haven't actually touched that yet. Will give it a tickle later, but it doesnt need to be washed at all.
All washed!
Wheel on with a bit of grease around the rubbing parts
I then gave it a blast with some finishing polish and the rotary
came up really well
The camera couldn't focus on the compact in the last shot, kept going for the ladder on the wall! Bit of wax when it's all finished and it'll look mint!
Motor seal
Gave the motor a bath in brake cleaner, and the top bearing a spray with plusgas, which soaked in nicely
Cord rewind and motor cover fitted
I then needed to go filter hunting. The black post motor 'filter' literally disintegrated and washed down the plughole when I put the shower on it. So I had a rootle around and found these
Which madea nice little upgrade once cut down a bit
Cut the other filter up for the pre motor filter
New Summer Meadow air freshener and H10 bag were found
Bag door has been refitted and that's it for now.
Posing with my other compacts
Hopefully more tonight! Got the tools to do too...
Cheers mate! It's a shame the extension tubes and hose are broken, would be lovely otherwise!
I put the top cover and latch back on
Then I whizzed over it with the rotary
Better, but it'll never be perfect
This still doesnt work either
Tools back in
The hose is holding up well now the glue has dried. Looks better than before anyway!
The extension tubes. I've already had a go at the top one, and it came out alright. So lets look at the bottom one
buggar, it's much worse!
At 1.5 degrees c, the glue was having a hard time holding, so Ihelped it with some temporary tape
tensioned it up quite well. Bought it inside to go off overnight
The top one after some finishing on the join
I'll probably not use these as I doubt their strong at all! Will either rob some metal poles from somewhere or just use another compacts toolkit for proper use
Having access to a 32mm contour head will come in handy though!
I dusted everything down, used my little wire brush to clean up the bristles, greased all the pivots and re-assembled it
All back in the box and awaiting final pictures and a good run round, before being boxed up and stored, as I have run out of room!
Before
After
Not much of a difference looking at those but I took them so up they went!
