I bought this new vacuum for my mom as a Valentine's Day gift. It's normally $170, but Amazon had it on sale for $99, so I went ahead and surprised her with it. This Hoover is replacing her Dyson DC07 Animal, which doesn't clean well and is just bulky, heavy and loud. As a result, I'm getting the Dyson back.
First impressions: This is an AMAZING vacuum!
Pros:
1. Very lightweight (14 lbs.) and easy to push!
2. Swivel steering makes vacuuming a lot smoother and easier.
3. Quiet! Even the brushroll motor has a pleasant sound to it.
4. Multi-cyclonic! The multi-cyclonic system consists of a large, low-efficiency cyclone, along with 7 smaller, high-efficiency cyclones, bringing the grand total to 8 cyclones. This allows for POWERFUL suction!
5. Phenomenal carpet cleaning performance! The WindTunnel 3 technology works exactly as claimed; the 3 channels of suction at the head, combined with the powerful brushroll, do a great job of removing deep down, embedded dirt. You can FEEL the brushroll getting into the carpet.
6. Does a great job of grooming the carpet!
7. Nice, long hose and wand. It comes with a combination dusting brush/crevice tool as its only attachment.
Cons:
1. The hose and attachments are inconvenient to use. To use the hose, you have to pull the connector out of its holster, flip down the nearby door and slide the hose into that door until it clicks. Once you're done, disconnect the hose and put it back in its holster. Not the best for people who use attachments often.
2. The 2-in-1 tool is another limitation if you use attachments a lot. It would be nice if it came with a stair/upholstery tool.
3. Dirt cup is small, but that's to be expected on a vacuum of this size. Pieces of lint and fluff tend to get stuck in it, which'll have to be pulled out by hand.
4. Vacuum does not work on area rugs because the super-strong suction chokes and snags on them.
5. Brushroll tangles easily, but not as bad as a clutched Dyson. A Phillips screwdriver is needed to remove 4 screws in order to gain access to the brushroll.
6. No headlight, but that's no big deal.
I was very pleasantly surprised by this machine! What do you think?
Pros:
Cons:
