Recently ordered one of these, as I was in the market for a new shampooer and wanted something with a decent tank capacity that wasn't too fussy to set up, and could be disassembled for easier storage. I noticed it was on sale for £129.99, which seemed reasonable, so decided to give it a try.
As a vacuum, it's seriously underwhelming. Not what you would expect from something pulling 2000 watts, plus it's way too bulky and noisy for everyday use. Besides which, I can't imagine many people being willing to fill, empty and clean out the collection tank each time they used it. I will say the water filtration does appear to work very well, however, so there is that. No debris or fine dust whatsoever on the prefilter, even after cleaning the entire house.
To me, the vacuum function is just a bonus feature that's there should I ever want it. Maybe if I was feeling masochistic, had too much time on my hands and fancied a change from my daily driver Sebo. I could perhaps see myself using it to vacuum out the car, but that's about it.
Anyway, the primary reason I bought this was for use as a shampooer, and that's really what it does best. The solution feed line is already integrated into the hose and wands, so there's no external tubing to hook up. Just click on the chosen wash tool and that end of things is done. You don't need to disassemble the machine to gain access to the solution tank either, because it simply drops into place on the rear of the machine. The solution feed itself is pumped, and there's also an onboard heater to boost the temperature.
For cleaning carpets, this is probably the best domestic machine I've used to date. Shifted heavy traffic lanes that a Bissell compact upright, Vax Dual V and Numatic George wouldn't even touch. The onboard heater gets the solution scalding hot, to the point where it visibly steams as it hits the carpet, and I think this is what makes all the difference to the performance (you can turn the heater off as well if you're a bit twitchy about using it on more delicate surfaces). It isn't tiring to use, and the extra capacity is nice, because I don't have to stop cleaning every ten minutes in order to empty and refill the machine. It also leaves carpets far drier than any upright shampooer I've used, to the point where they were completely dry within three hours rather than overnight.
In short, it's a crappy vacuum but an excellent shampooer, so for my needs it's absolutely perfect. The reviews out there seem to be polarised between loving it and hating it, but other than that there isn't much info on this product. I see it's also available in the US; anyone else tried one, and if so, what are your thoughts?
Link goes to a video on the Youtoobs from a dealer in South Africa (I think?) that explains the machine far more succinctly than I ever could. Enjoy.
http://https//www.youtube.com/watch?v=bLhsfVR2WNI
