Has Any Dyson Had Variable Power?
hi-loswitch98
I don't think I have ever known one, but if not does anyone know why? Is it to do with the Cyclones or anything?
Dyson did use a two speed YDK motor in the DC04 Zorbster. When the clear bin was removed, the machine fan on "lo" speed to scrub in the powder.
There hasn't been..
Any UK models with variable power..
Just a suction release trigger on the handles of the cylinders I think.
I've always wondered if it was to do with the cyclones, meaning that at low power the cyclones wouldn't separate dust as efficiently. ? Hmmm.
It's not until recently that I have understood the need for variable power. I used to want high suction at all times. But low power equals low noise, which is important for midnight cleaning!
I'm not sure if I remember seeing some Chinese models with variable power. I know they have models that have the power switch on the handle (on the cylinder machines) can't confirm whether I remember a plus and a minus on there too.
As has been said, the closest to variable power is the 2-speed Zorbster.
James Dyson has said in one of his books how much he disliked gimmicks and buttons (or at least words to this effect), hence why his uprights have never had a foot release pedal.
Dyson thinks that an air control on the hose is enough to adjust suction power.
Take a look at the Hose cuffs on certain Dyson uprights like the DC07 and DC14. they have holes, so you can push the tools in all the way, or just a bit. The airflow holes in the crevice and stair tools also help with this.
The Dyson handheld models after the DC30 (not DC16) have a boost button.
The Dyson DC04 clutched model's hose cuff has a semi-circle release button for the wand, and a circular button for suction reduction.
The Dyson DC01 and DC03 for example didn't need this.
The Dyson cylinders, however have a manual suction release valve which the user can optionally choose to reduce the suction or not, again similar to the DC04 clutched model's hosecuffs.
The Dyson DC12 does not have an electronic suction reduction feature.
Well...
The turbine brush looked like it was air driven and the DC39 was the first dyson to have air turbo head on/off. I watched a video of a DC12 and the lady using it was able to make the suction increase...
Actually, I think I mzy be wrong about the DC12, the buttons may be for the suction!
Dyson handhelds on the other hand, have the boost button which increases the motor speed so it makes the entire vacuum including the brushbar have more power, but shame that it's only 6 mins
dc12 2 speed
to me that looks like a filter light, on green it is fine on orange you wash the filters and on red you call the helpline as clearly shown by the little images above each shade of light
Dc22
In the states we had the compact canister called the dc22 with the brushless motor that had two speed. However at $800 it was expensive and small.
The effectiveness of the cyclones depends on air speed, so decreasing the speed would make them less effective.
