Hi all,
I am seeking expert advice from those of you more experienced than I with Hoovers.
Sick and tired of my not-so-smooth sounding Concept 1, I have set out to replace both the 608 sealed ball bearing (fan side) and the horrible little Torrington J-65 needle bearing (belt side).
I have already replaced the fan-side ball bearing. Drilled out the rivets, replaced with a new sealed bearing, re-riveted, etc, and this has helped with the scratchy noise, but the old, remaining needle bearing on the other side still sounds loud.
This is the replacement I have ordered. It is basically a direct replacement, albiet from a different supplier:
https://www.amazon.com/gp/aw/d/B007EDPXKI/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
I suspect this bearing will demand I "lubricate before use." This is fine, but I want to make sure I use the right grease before I put this beast back together, lest I take it all apart again later on. For my vacuums, I have this grease that I use with a syringe:
https://www.walmart.com/ip/Super-Te...35&wl11=local&wl12=16928004&wl13=4299&veh=sem
Is this suitable for the first and hopefully only greasing of this brand new bearing? What grease do you all use to pack needle bearings?
Thanks. I'll let you all know how it works out.
broomvac
broomvac
