vacuum devil
Which backpack has the problem, the Sanitaire or the Great Vacs one? I'll keep that in mind when I use it, hopefully it will not happen on mine. Wonder why it melts. The interesting thing about backpack vacuums is, people either really like them or they hate them, there's not a lot of in between. I like any type of canister cleaner so I actually really like these, and especially when combined with a sidewinder floor attachment, you can clean really fast. There's also 10 quart Hepa cloth bags you can get for these if you'd rather not use paper bags. For the most part, the bags and hoses are interchangeable. A couple other backpacks I have are the Windsor 10 quart, the Sandia Raven 10 quart and the Powr-flite comfort pro 10 quart. I do think the Powr-flite and Sandia machines have a design flaw. On the Powr-flite, the 50 foot cord is hard wired to the machine, I have no idea what the logic was for doing this. Most backpacks just have a short cord that you connect to an extension cord, if you only need 25 feet, use a 25 foot extension cord, very simple. Fortunately that is easily fixed, cut off most of the cord and attach a plug to what remains, then take the cord you cut off and attach plugs to both ends and you have a nice new extension cord that you can use. The Sandia raven is an example of why it's better to leave things alone when they work. With most backpacks, the hose goes straight in to the top cap, but with the Raven, it's curved and slanted. Supposedly this prevents objects such as paper clips from damaging the bag and it increases airflow although I really don't notice a difference. So, with this design, apparently the hose kept disconnecting from the machine, so they developed a lid that actually has the hose as part of it. If something happens to your hose, you have to replace the entire lid assembly. Fortunately they offer a regular lid with a hose in-let which I purchased for mine, but again, if they had stuck with the regular design none of that would have been necessary in the first place.
Mike
