G.E. cordwinder repair question
kloveland
Tulsa
I recently acquired this G.E. Swivel Top from a VCCC club member. The cord winder will not retract. I took the cord winder apart to discover that the coil/spring is broken. Can the this be repaired? Is it possible to solder the broken spring/coil back together and will it hold?
The spring looks like it was riveted into the center hub. It might be possible to reattach the coil to the center hub. It looks like I will have to take out the rivet. I'm really not sure what to do! Was hoping a G.E. expert would have some suggestions!!!!
