Thought this would be an interesting topic, there is no right or wrong answer, but, what does everyone think of a frankenvac, that is, combining attachments or power nozzles from other vacuums? I can see both sides to this, some users may want to use only the attachments that a vacuum includes so it works the way the manufacturer intended. On the other hand, if you can enhanse how well a vacuum works by using other attachments, that's a good thing. I fit in to the second category, since all of my vacuums are canisters of one kind or another, I have lots of different attachments and power nozzles. I actually tend to avoid vacuums that do not have a standard hose end and if applicable, a standard power nozzle connector. Wondering what everyone else thinks. Do you combine other attachments with your vacuums or do you only use the attachments that were made for them? It's really common to do this with central vacuums since most central vacuum attachments, besides Electrolux and Beam use a standard hose end, but I think it's also interesting to combine something like an Electrolux 1205 with a Sebo power nozzle, or the Riccar Prima with the Centec CT10 power nozzle? So many different combinations are possible.
Mike
Mike
