First Electrolux
JHGVac
I picked up my first Electrolux today, a turquoise Model L.
It has the belt winder but no power nozzle. It has a fair number of scuffs, but no major dents. Fairly clean as well, the pictures are before any clean up.
I think the wands are not original. They seem to light weight and flimsy compared to everything else on the vacuum.
Those wands are actually original. That is one thing that I like about the older Electrolux wands, they are very lightweight! That is an awesome find though!
Excuse me, "too light weight."
Any cleaning tips? So far my only experience is with Kirby vacuums, which have little painted/enameled surface.
Joe
@ vacman117
Oh, that's good to know. They don't have any markings on them either. I'm glad I didn't leave them behind now.
Thanks Chase!
Joe
Awesome Electrolux!It looks to be in nice shape!I have one Electrolux myself and they are terrific Vacs.I'm sure glad you were able to save it.It is a really well preserved machine and I love the styling they had on the model L to me it has a classy look to it and I heard that the Model L was one great vac to own in it's day.Awesome!
I wanted to add that the minor scratches come out great with soft scrub or a light rubbing compound.If you lightly use soft scrub and a little windex followed by a little car wax the finish should turn out beautiful.Also a light rubbing compound followed by a damp rag then some hand buffing should take the marks off of the plastic as well as the paint.Just don't rub to hard on the painted surface as you want to apply it lightly but buff clean after a rinse with a damp rag.I've always had very good success with those cleaning tips
That and toothpaste works well on the rubber as well just be sure to rinse it off wiping it with a damp rag afterwards.Great find,I'd be proud of that one if it were mine.
@ tyson
Thanks for the tips Tyson!
I am pleased, the thing runs like a top and makes a pleasant whooshing sound.
Joe
Joe:
Your Model L would have been made sometime between 1968 and 1973; these were the years that the L was finished to match the TOL Model 1205. I have one in storage that's identical to yours.
You did very well for $12! The fact that the wands, the combination floor/rug tool and the crevice tool are present is a huge plus. You lack only the combination dusting brush/upholstery tool to have your machine complete.
Turquoise dusting brushes in good shape are getting a little hard to find. There is a soft rubber part inside the brush that tends to crack and tear over time. If you find a dusting brush with this problem, there is a fix: SuperGlue. It bonds rubber perfectly.
If you want a power nozzle for your machine, the correct ones for that vintage Model L are the PN-1 in turquoise, or the PN-2, which was a polished aluminum unit. Early Ls used a non-electric hose, with a separate cord that was clipped to the hose with turquoise plastic clips. You can still buy the cord easily on that auction site, but the clips are unobtainium new; your only chance at them is used. You can also use Rainbow hose cord straps (which come in black only). Late Ls used an electrified hose with a "pigtail" on it to plug into the power nozzle port. The 1974 gold L I just found uses that arrangement.
If you want to put a PURDY shine on your L, I recommend TR-3 Resin Glaze, a car polish/sealant available in auto parts stores. You will end up with a blinding shine on that beautiful turquoise paint.
Another thing - all the brush bristles on your tools are replaceable. That auction site is one good place to look for them if you ever need them. Even the dusting brush's bristles just pull out (they're mounted in a metal strip) and a new set snaps in. Also, that cordwinder is rebuildable if it ever gets lazy about rewinding the cord. You will improve the rewind a lot if you will make sure the cord is clean and then dust it with a little talcum powder; that was Electrolux's recommended lubricant for the cord.
Great machine! You're lucky.
Thanks Sandy!
Wow, lots of good info there.
Was the power nozzle an option on the Model L? Based on the amount of stuff the owner of the house hung on to, it seems like it should have been there had they ever been in possession of it.
Also, the little receptacle for the PN has a rubber cover that plugs in, and it's still nice and tight with good insertion force as if it seldom has been opened. So I suspect this one has never been used with a power nozzle.
Joe
