Those are so simple, very similar to an elite for opening up. There is 4 clips/tabs on the corners of the hood, one at each corner. I believe the front ones are at the sides of the brushroll housing, the back ones behind the wheels. The hood should then pop off. There is either 2 or 4 screws holding the motor housing to the base and I believe 4 on the fan case itself.
