Eureka model data so far
Ah I see, wow. Yeah I wonder if that's why this is rare? Either nobody bought it, or they all got used up and junked?
There was a Montgomery Ward shampooer paired with this in the store that I also bought, that is from 1978, and I wonder if both of these came from the same house and the person was a real money miser and just bought the bare minimum of everything - as they actually wrote the price of the shampooer on the manual - $38. It was a very cheap shampooer.
Also makes me wonder if these were from the same house, if the Eureka also came from Montgomery Wards too?
Added to 1400--I think it's Brandywine?
SERIES MODEL NAME/STYLE FEATURES BODY COLOR OUTER BAG YEARS
1400 INTRO. 1974
1401 CLASSIC BGT WHT/BLK WHT 1974-76
1402 CLASSIC BGT WHT/WHT WHT
1403
1404
1405
1406 CLASSIC 2 POS DAN LB LB 1980-81
1407
1408
1409
1410 CLASSIC 2 POS DAN, HL WHT/GOLD WHT
1411
1412
1413
1414 BICENTENNIAL 6 POS DAN WHT/BRN BICENT. 1976
1415
1416 CLASSIC 4 POS DAN WHT/LB WHT
1417 CLASSIC 4 POS DAN WHT/ LT ORN WHT
1418 CLASSIC 6 POS DAN WHT/RED WHT
1419 CLASSIC 4 POS DAN, HL WHT/GOLD WHT
1420
1421 CLASSIC 6 POS DAN/HL WHT/RED WHT
1422
1423 CLASSIC DAN, HL WHT/LT ORN WHT
1424 CLASSIC 6 POS DAN, HL WHT/RED WHT C. 1980
1425 CLASSIC 4 POS DAN WHT/ORNG WHT V
1426 CLASSIC 4 POS DAN BLK/WHT 1974-75
1427 CLASSIC 4 POS DAN, HL WHT/BLU BLU 1981
1428 CLASSIC 4 POS DAN, HL WHT/DK BLU PL V
1429 CLASSIC 4 POS DAN WHT/RED PL V
1431
1432 CLASSIC 2 POS DAN WHT/RED WHT
1435 MOD CLASSIC 2 POS DAN DK BLU/WHT WHT
1436
1437
1438 VANGUARD 4 POS DAN WHT/RED WHT PL
1439
1440 FLAT HOOD 6 POS DAN WHT/BLU BLU 1975
1441
1442 CLASSIC 4 POS DAN DK GRY/WHT WHT
1443 CLASSIC 2 POS DAN BW/WHT WHT
1444
1446 VANGUARD DAN WHT/DK BLU
1447 4 POS DAN, HL RED/WHT WHT
1448
1450
1452 VANGUARD 6 POS DAN, HL BW/WHT WHT 1984
1453
1454
1455
1456
1457 DAN, HL RED/WHT WHT
1458 VANGUARD 6 POS DAN BLU/WHT BLU 1979-83
1459 VANGUARD RUG, HL WHT/CINN WHT 1986
1462
1463
1466
1469
1470 CLASSIC 6 POS DAN, HL RED/WHT WHT
1471
1473 FLAT HOOD 4 POS DAN, HL DK BLU/WHT WHT
1475 CLASSIC 4 POS DAN BLK/WHT 1984
1476 CLASSIC 4 POS DAN TURQ/WHT WHT V 1986
1485 MOD CLASSIC 4 POS DAN, HL DK BLU/WHT PL V
1486 CLASSIC 4 POS DAN, HL GRN/WHT
1489 FLAT HOOD 6 POS DAN, HL DK BLU/LT BLU LT BLU
1490
1495
Doesn't the '9003' serial number leader indicate the third week of 1990 or March 1990?
I'm also guessing that the '4' of the 1400 Series indicates its 1974 debut. If so, the 1900 Series would have been introduced in 1989.
You might try getting some information from Eureka and local vacuum shops like I did with Aerus.
Keep up the good work on the model list. You're making progress!
Hi Paul,
I don't think Eureka's serial numbers worked like that...the font used for that model is definitely from early to mid 1980's. After around 1984 or 1985, the brandname lettering became slanted/italicized.
It is possible that the 1900 series began in 1979, if I remember correctly.
I might have a lead. I found this article however it is from 1978 but I can't view or enlarge it. It mentions an Eureka Model 1443, but with 6 pos. dial-A-nap and headlight, before the OCR devolves into gibberish. It is a store ad for a place called "Woolco".
Thanks, Brian.
@huskyvacs Good info. Regarding Woolco, here's a portion of what Wikipedia has posted:
"Woolco was an American-based discount retail chain. It was founded in 1962 in Columbus, Ohio, by the F. W. Woolworth Company. It was a full-line discount department store unlike the five-and-dime Woolworth stores which operated at the time ... "
<span style="white-space-collapse: preserve;">I got a useful bit of information from a former Eureka (1978-2014) employee:</span>
<span style="white-space-collapse: preserve;">So, that's a little background. Now, to your questions. Model numbers were the main identification control, of course. But we would have run out of model numbers in no time if we hadn't used the model letter suffix, or "type", as it was labelled on the data plate, to indicate changes that affected servicing the machine. So, your 1428 might have been a 1428, type A. We might then have changed it to a type B if a part changed that was not interchangeable with mating parts. Or, I remember when we changed the handles from steel to ABS plastic we advanced the letter on models that were affected. Model numbers were indeed used to control which retailers got which models. We used higher specifications (amps, height control, type of bag, etc.) for department stores and vac shops (they were major players back then), and retailers like KMart, Catalog stores, etc. had different model numbers with different specs. There was no quality difference in how the models were manufactured. But specification differences in convenience features, filtration efficiency, design trim, and of course motor types. We private-labelled for Montgomery Ward and JC Penny, so they used their own model numbers.</span>
<span style="white-space-collapse: preserve;">As for serial numbers, I'd have to say I'm taking an educated guess. When I started with the company we bought pre-printed data plates so those most likely were grouped by model number. But eventually we produced our own plates, and then eventually produced them on each manufacturing line, as I recall. The serial numbers started with the week and year of manufacture. But the numbering system changed in later years, and I can't recall in what way. In general, a series of cleaner was built on a dedicated production line, so it is likely that you would have a long string of sequential numbers on the same series, but individual models might only have 500 or a 1000 run at a time before changing to a different model in that series. And then of course, the next week the numbers would start over with the new week.</span>
Very revealing - thanks!
I wonder if the person or someone else knows how the Eureka brand model numbers were selected, because the model numbers themselves don't seem to indicate trim differences albeit the Series does (2300 Continental Series, 600 Series, et cetera). Correspondingly, the model numbers do not appear to follow a numerical order.
