Well I tried to repair the problem myself but couldn't get the height control to work. I used my X5 as a donor model to test various parts but the problem remained. I swapped the pcb and the servo motor for the wheel but they didn't work in the Ensign. I was more worried that the X5 wouldn't work after removing some parts but thankfully once assembled it was fine.
It is such a shame about the Ensign because the motor works, the brush turns and it looks brand new apart from a small scuff on the cleaner head. I emailed the seller and they refunded me straight away and said I could keep it, so at least I haven't lost out. When I have time I will delve deeper into the cleaner and see if i can rectify the problem, but it will be on the back burner for quite a while while I get on with the many other things that need doing.
