Elux Bags....
fantomfan57
Austin Texas
Hi folks, so I am asking if anyone has or can point me to a source of the Canadian version of the self sealing Electrolux bags.
The manual calls them Elux bags, instead of Electrolux bags.
I would like just one package to finish up my ZB89 Elux-o-Matic ensemble.
Hope to hear from someone or discover some on Ebay.
Thanks,
G.
Compatibility?
I don't know the answer to this, having never encountered a Canadian Electrolux in the flesh, but do the 'C' bags for American models not fit the Canadian units or are you just going for total OEM originality? I'm certainly not criticizing, if that's the case, but good quality, third party versions of the 'C' and 'U' bags are plentiful and cheap online. I run Multifilter 'C' and 'U' bags in all my (American) Electroluxes with no issues.
Thanks, Ed and AC
When I received the Elux-o-Matic, it had a bag that I have never seen...I should have kept it. It looked like it was in French. I stupidly threw it away to keep from breathing unknown dust.
Yes, the Canadian canister uses the same C bag as the American machines. I just would be curious to if there was a package made in Canada for Canadian Elux Vacs.
I found the alternative is the Genuine Electrolux DIRT GRABBER...the collar is both in English and French.
BTW! I was looking just now in the garage in a tall hamper with different vacuum wands and found......a blue version of the Canadian telescoping electric wand!
I cleaned it up and will try to see if it works Friday.
Cheers!
Hi there Bikerray
I always enjoyed reading your Thrift Store discovery posts.
I like that design, but the one I discarded had a yellow background with I think, blue writing.
The example you have, would be great to have. Do you have a source for me?
Telescoping Wand...
I have one of those telescoping wands in teal. It came with one of my 1205's, along with a teal pistol grip hose and a PN-1 that's not riveted to the wand. It's really a cool and convenient design. I wish they had kept on making them.
Goodness!
Here I was trying to describe the bag and I had the picture of it all along.
Again, wish I had saved it.
The bags will turn ups somewhere, eventually.
Telescoping wand
Seems two subjects ended up here. Here in the states the telescoping wand was introduced with the 1205 and while it is interesting, it was quickly discontinued because when extended, the upper portion is not reinforced with metal and would crack easily. Also the plastic around the top plug end would be prone to cracking and breaking. I am not sure if the teal blue early automatic plug in hose handle swiveled or not, if it didn’t that could have been a problem as well, if it did, perhaps the electrical parts of the swiveling system weren’t reliable enough. Hence they quickly modified it to become the blue sheath over metal wand design without the automatic electrical connection and they changed the electric hose handle too to one with the curved all metal handle that swiveled and the dual outlet on the collar. The electrical outlet on the hose did not swivel but the metal handle did. The sheath got downgraded to just have a cord hanging out of it that one had to plug in to the outlet on the hose.
Anyway, I feel like this was a “prototype” design for what is currently still in use today on the Aerus Lux Classic and was reintroduced here in the states in 1974 on the Golden Jubilee.... The automatic electrical connection between the hose handle and the power nozzle wand. It was improved and beefed up in the mid 1980s as a lot of the sheaths were breaking at the top around the power plug causing a poor connection so that was beefed up, and the upper metal wand inside the sheath's design was changed to the current fastening system using the indented slots on the hose handle instead of the pressure grip ring system. I believe this helped to eliminate the handle from being able to twist in the wand which may have been causing some of the issues of breakage of the sheath at the power outlet and quick wear on the hose ends outlet too. The newer design using the slot to lock the handle in place does not allow it to be twisted left or right like the pressure ring allows.
Just some observations. While some may complain that Aerus hasn’t changed much in many years, I still find this metal wand system with the sheath and the pistol grip handle to be the easiest and most comfortable and ergonomically correct hose handle and wand design on the market today. I’ve been hard pressed to find something I find as easy to use or ergonomically correct and comfortable to hold and still fit into small spaces like when having to clean out my car. Gas pump handles are all bulky and hard to use, anything where the handle doesn’t swivel where it connects to the hose is annoying, even if if the hose swivels where it connects to the machine instead, that just doesn’t work right and I’ve found I have to untangle the hose periodically on those types.
So...”if it isn’t broken...and is a great thing....then don’t fix it” is the philosophy I think Aerus is using to keep this hose handle and wand system still in use today on their base machine...it is a time proven system that is very durable and reliable in an area of a vacuum cleaner that sees a lot of heavy use...and abuse...people who have had it are used to it and like it, it works also with machines that have been made for over 40 years so it supports the replacement or upgrade parts customer market. Though adding a switch to turn on and off the power nozzle on this hose handle is something they could do...and aftermarket generics have done, though those little switches tend to get bumped easily and turned on or off when not desired to be switched on or off and is another source of something to get broken so perhaps is why they haven’t done it on this model of hose handle and opted to keep the switch on the power nozzle itself which can be operated with one’s foot or hand.
Jon
The handle on my teal pistol grip hose does swivel but it has cracks where it joins the hose, which is why I've retired it in favor of a vinyl OEM replacement. Amazingly, the hose still had great suction the last time I used it, which was about seven or eight years ago.
I've got a couple of aftermarket hoses that have a switch to control the power nozzle. It's a feature I really like in that I can instantly turn off the power nozzle if it catches something it shouldn't. But as Jon mentioned, the rocker switch on the underside of the handle is a bit problematic and I do occasionally hit it as my hand slides on the handle a bit. I do have one aftermarket hose that has a slider switch on the handle that barely sticks up beyond the handle and is stiff enough that it's fairly difficult to turn off accidentally.
Garry,
I'm not sure if it still exists, why not give it a try? The toll free phone number on the form is 1-800-668-0763 (or -0765, the number on the front page and the back page aren't the same) for Canada and 1-800-243-9078 for USA.
I found this form in a original box of Electrolux bags, I don't know how old it is.
