aeoliandave
The other day a chrome XXX cordwinder arrived in the mail - I took a chance at the poor picture and I was right - it's all original with Belden plug, cord, socket & all - the motor pigtail plug still has flash around the seams. The perfect reason to strip down the 535 watt XXX with the LX patterned leatherette gifted to me by John Long.
LX blue looks so perfect on the XXX. taken apart it is obvious that the leatherette was die cut to the XXX pattern and meant as a Factory or Factory Outlet upgrade for older XXX's to sell alongside the new LX. This one is neatly glued down over the original leatherette, but I imagine it was meant to have the original stripped off first. There is no way you could use the LX pattern to re-cover an XXX.
I used the Kirby Classic Handi Butler buffing wheels and compounds to shine things up. Next I will go at it with the finer compound on the dremmel.
Well, I just love it so much I paired it up with a saddle and tools and aluminum wands. I have 3 LX pattern hoses, two cloth weave that need the latex treatment and one gorgeous saran weave that still has no leaks. I'll use the cloth weave for display but the saran for actual use. And no, I will not keep the leatherette covered with a saddle...it can borrow from an LX neighbor at Luxious Towers.
