Electrolux xxx not turning on
kirbyman65
USA
Hello!
I need some advice for my Electrolux xxx. I received it yesterday and it didn’t turn on. I have no idea what’s wrong with it but any advice would be extremely appreciated.
J-
Check continuity through the cord. Also check the carbon brushes as well as the commutator for wear. That's an OLD motor. My model XXX's all needed to be completely rebuilt when I got them, which I did. Also check the two ball bearings, they may be in need of grease.
Thanks!
Its most likely the cord since the seller claimed it worked, hopefully I can get a replacement
Seller claimed it worked and it being a nearly 100 year old vacuum do not correlate.
Verify the cord is safe and has continuity. If it is the original cord good chance the wires have broken inside or it might have a dead short, would need to be analyzed. Next thing to check would be the socket on the vacuum where the cord plugs into, it is easy for them to tarnish and lose conductivity. After that, check the on/off switch, the pins can get dirty and not make a good connection inside the switch and prevent it from turning on.
Looking at the photos, the cord looks brand new and depending on if it is an aftermarket cord said to fit the XXX, or just some random two pin cord they found somewhere, it likely is not fully seated into the socket, or the wiring to the prongs is not secure enough. Make sure you have it on the right way too, sometimes those cords were polarized and only worked one way.
If one is careful enough you can disassemble the machine plug end and put a new cord on. Cords for these XXXs with the round prong ends are getting rare and rather expensive for a cord.
