Hi All,
I may or may not be done with my Silverado Deluxe rebuild. I totally disassembled the PN5 power nozzle today and cleaned it and put it back together. It runs great. But...
When I took the rear wheel assembly off by removing the cover over the axle it pretty much just sprang apart, so I didn’t know how it was supposed to go back together. When I put it back together, the spring required about a ¼ turn in order to get the end of it in the hole it is supposed to go in. As a result, the back wheels are “jacked up” or extended raising the rear of the power nozzle. You can push down on the rear of the nozzle and the wheels go down or up depending on how you view that, into their recesses and the front pivots up a little bit.
What is the purpose of the spring on the axle and did I get it right? I question if it is correct because the pn really seems to be bogging down on carpet because it is forced down by the wheels as well as sucked down by the awesome suction this machine makes.
My other question is related to the neck. Is it supposed to be totally lame, loose, floppy in its fitting? Is there supposed to be felt strips around it to seal it? Mine is really floppy in the housing. When you put it up into the park position, is there supposed to be any detent or anything. Is this related to the axle and spring I think I have wrong? Sorry no pics for now, but if anyone can help me please let me know.
Thanks in advance,
Andy
Thanks in advance,
Andy
