Electrolux olyimpia power nozzle question
kirbyman65
USA
Hello! I finally finished everything I needed to get done with my Electrolux olyimpia, but there’s one issue with the power nozzle. It’s hard to see in the photo but every time I use it, it’s so high! It doesn’t even agitate the carpet! Any way I can adjust it lower? Also how do I date it? Any advice would be greatly appreciated!
-Jack
They have springs
They have springs, but how should they look? I replaced the rear wheel cover, could something have gone wrong then?
Nice late Olympia--
--later Power Nozzle, good generic hose. As above the spring pushes the wheels down and lets them raise when pushed on thicker carpet. You probably need to - remove axle cover, lift out wheel assembly, wind spring until short end rests on notch, replace with long end of spring in hole behind motor, replace cover. ( Some early covers would have tabs break and fall out. Replacement covers would be improved. )
Thanks for the help
I have no idea what I’m doing wrong, Any ideas? I’ve tried 5-6 times.
Thanks again
-Jack
