I have an Electrolux Automatic Model G (pictured, I hope) my mother gave to me several years ago when she desired a newer model. Never really used it as I my house was under renovation and the Craftsman shop vac was fine but now I need the Electolux. Problem is when starting, with a new bag inserted, the motor switches off and the front drops down. I have researched on the internet and read the available manual for the Auto G and understand the feature. I read a posting by Henry200 of St. Paul MN submitted 7-1-2011 where he described this problem and a remedy of cleaning the small plastic tubes in the front compartment which I did. I was surprised to find there was no dust at all under the metal plate that separates the bag compartment from that front assembly ( whatever it is named ). None of the tubing was obstructed, factory fresh. Put it back together, switched it on, operated fine, attached the hose, OK, attached the crevice tool and it switched off and front dropped open. Keep in mind, unused bag. The hose and crevice tool were unobstructed. I tried different positions of the advance and retard dial to no avail. Took it back apart trying to think as a mechanical engineer and noticed the fitting on the dirt intake tube does not have an opening on the plastic tube end. Curious. Why run a tube to a fitting that is not ported? I used an angle awl to clear any dust from the interior of the intake tube. I can force the vacuum to operate and defeat the automatic feature with a long bungee cord wrapped around it but I do not think it wise. I'll bet one of you experienced Electolux experts know exactly what is going on. Will you please advise me? Thank you. Kesler
