Reply to thread
O.K. kids, this is going to be lengthy,
so go get some coffee. The control does not change motor speed. It is simply a pneumatic system of valves, diaphragms, springs and tubing. I'm going to talk about the system found on Lux models AE through -(not current on new Lux so I don't know when or if they stopped using it)at least all metal bodied units. The same system is used on the LX but more involved and more mechanical but the pneumatic part of the system is basically the same. When you take the cover off of the front bag "door" to reveal the control knob and tubes, you will notice that one tube comes from the (in most cases) clear valve casing to the bag/hose inlet tube(where you connect the hose). Another tube goes to the cover itself which via a small rubber "nipple" connects to the suction side of the bag chamber. On 1205's onward, you will notice a little brass rivet just about an inch below the latch on the top of the bag chamber, that's where the nipple connects. OK, ya still there? One more tube comes from the valve and goes to a diaphram. You will see the front cover latch connected to this diaphram, some springs, etc.(on I believe F, and I know G's have additional levers and spring to hold the cover latch lever down when the cover is open or when there is no bag in the chamber. on 1205's this extra mechanism is merely replaced by a switch that shuts the motor off. But I'm sort of getting ahead of myself. When there is a UNCLOGGED bag in the vacuum, vacuum "pressure" is equal at the hose connector, and the bag chamber. so nothing is taking place with the automatic control at this point. Once however, the bag has become clogged, suction at the bag chamber is higher than it is at the hose, the control valve "senses" this and starts to move a diaphragm toward a cylindrical shaped "inner" valve. This inner valve is connected to the knob that either says advance, retard or later had bars or numbers or words telling it's position. e.g.1-6 fine-course. The greater the number, or setting determines how much suction is necessary to move that inner valve. Greater suction is determined by how clogged the bag is. (bathroom break) Now, once enough suction has entered the control valve to move the inner valve about an eighth of on inch, or so, vacuum is admitted into that diaphram, it is sucked down, moving the levers that will open the front cover, shut off the motor, light the check bag light, (1205 on). On the AE-G there is a spring loaded rod extending from the front trim area that goed to the motor control switch at the rear of the machine. You can see this switch move when the front cover opens. That's BASICALLY it. I hope I didn't bore you. I'll explain the LX later today, Don't have time right now. I know you'll be waiting on pins and needles for that. In the mean time, any more questions please post them. If Iknow the answer, I'll write back... Rick
