Electorlux S165A Floor Shampooer squeaking wheels
lux165a
aa
Hello, I have an Electrolux S165A Floor Shampooer that is really squeaky.
I took it apart thinking it was the belt, and discovered that the 2 non-drive white wheels are loose and they are what squeaks.
My question is, can these be removed and tightened? I don't see how they are attached and don't see a way to remove them or tighten them?
Attached are 2 pictures, 1 of the wheels that I am referring to, and 1 of the label.
"--way to remove--"
Under the plastic motor cover at front over pulleys you will see 2 round metal caps that could be removed to expose clips and washers.But removing them would damage them and require repair or replacement(Elux branches could order these).They rarely needed attention.
