Dead vacuum
fiery
I purchased a Hoover Elite Vacuum which I love! I was using it today when it just stopped working without a warning. I cleaned it out and tried plugging it into a different outlet but it will not come on. I'm hoping somebody has a suggestion as to what the issue can be.
Did you let it sit for a half hour? Maybe it overheated and the temp switch kicked off. Also possible the switch broke or the motor is toast.
Hoover Elites don't have reset buttons, and the switch is NOT easy to replace. The field coil wires are hard wired directly to the switch. You'll need a new Elite switch, a soldering iron, some solder, needle nose pliers, and a good idea of what you're doing before taking the motor out. Most of the time when an Elite just 'dies' it's because the field coil wire burned out and broke off from the switch. It was a rather poor design.
Just a thought... Try pushing really hard down onto the handle. There is an inner plug at the top of the motor where it connects to the upper half of the vacuum and sometimes it becomes disconnected. It has happened to several of my Elites that I originally thought were dead.
Hope that helps!
Chase
Is there not a new version of the Elite? Maybe this is what the original poster is referring to (the bagless version), in that case, I would check the filters, and wait an hour or so before trying it again. Those DO have a thermal overload fuse.
Don't overlook the 'obvious'
The mains lead (cord) on any vacuum is subject to lots of movement, pulling, etc. they are prone to failure, usually where they enter the 'strain relief'at either end. If it's a re-wireable plug, have you checked for loose screws/fuse (if fitted in U.S. plugs)??
All best
Dave T
What could have happened,
Was the plastic "Rod" which leads from the handle to the inner switch has busted, this has happened before to me once, one a Twin-Chamber machine. I believe these parts are N.O.A (No Longer Available), but if your lucky your local shop may have one.
It may be a pain to replace, but you could always just rip out the busted rod and do it the "Quick-N-Dirty" way of flipping the internal switch and wiring a in-cord switch onto the cord. We did this years ago, to a Fantom Thunder.
(By the way, "Rip" and "Hoover" should never be in the same sentence,
-Alex.
