Damage from using it as a blower
rivstg1
colorado springs
Here are some pics & an explanation of what can happen to your kirby fan when using the machine as a blower with the supplies nozzle guard from a kirby technician of 40 years.
“ This is the result of using the air intake nozzle on the sentrie and later kirby when in the blower mode.
Completely restricted air flow due to stupid design.
Shame on kirby!
The heat buildup was so extreme, look at the angle of the fan blades.
This all happened in less then 5min.”
Recommended action: 1, use an earlier model nozzle guard which has more airflow
2. Drill many more holes in the factory nozzle guard ( Sentria1 & newer) to increase airflow
Pics: G5 nozzle cover, sentria 2 cover, & Legend 2 covers....notice the opening sizes
That is just WOW!!!!. When I use them in blower mode. I just raise the head to it's highest setting.
Do you know how long the machine was used in blower mode to heat up the motor enough to damage/warp the fan?
Diamond Edition
I have a Kirby Ultimate G Diamond Edition and it has the same air intake guard as the G5 except in a different color. Is the air intake guard that was supplied with my Kirby sufficient or does it require modification?
@mmcphee. if its like the G5. no problem . Its only the Sentria I and II and avalir styles that are too restrictive.
one can just use a drill bit and make the opening much better for airflow.
@kirby519. it was stated that under 10 minutes did that. I kinda wonder about that though....sounds too quick. I've used mine while having the Hand butler tool 2 attached to a Sentria nozzle cover but noticed no issues....I sold it before I could check it out again ( inspect the fan)
The reason for this is that the method was still kept the same even though the Kirby's construction changed. Once the switch to a plastic fan was made, there was greater risk of heat exposure and melting, and the airflow was less, compared to the metal fan era.
Also I never at all used those novelty tools. I think once I used it to blow the dust out of a PC but that is not good because the tools generate static which can kill your PC.
You will get a lot better results and more airflow using a real inflatable blower. No reason to modify or ruin the tools.
It does seem kind of dumb to even waste your time putting an extra piece on the machine, when you could just leave it open or lift the nozzle off the carpet.
So far I have been lucky with mine. I do use it for air cleaning operations. Thankfully none last more than 10 minutes.
I have used my Sentria to inflate a kids pool a few times. I may very well rethink that operation.
The other thing that is amazing is the fan blades warped in the in the direction the fan spins.
I would think they would warp in the other direction. Meaning the blades folding over bending against the direction of the spinning fan.
Rather than folding back which would relate to the actual direction the fan is spinning.
It’s not common, but have have seen both a Kirby fan and a couple others deform like that. I wasn’t able to tell on the Kirby but I got the sense they used it heavily with the hose, the other machines I saw this in were run clogged for an extended period of time. I had no idea using the blower function would also do it!
Restricted air flow will do that. Not enough cool air going across the fan to keep the fan cool.
Same thing happened with the Kirby with the additional speed switch. the motors don't turn fast enough for the motor cooling fan to draw enough air across the motor to keep the motor from over heating. Is why that option was discontinued.
To many in the general public didn't understand that was only to be used for just a few minutes to vacuum a scatter rug that you couldn't do with full cleaning power.
The Kirby Diamond Edition Overheating Myth Busted!
Electric motors run cooler when running slower, not hotter. Therefore, less cooling is required. While I'm sure that there are plenty of ways to break a two speed Diamond Edition, running on low speed isn't one of them.
Bill
I only really use my Kirby’s as uprights, mostly because I am just so much more inclined to use an upright, then just use a suction only hose on the central for all the tool use rather than bothering with the upright tools.
As to the Kirby burning out, I was under the impression it wasn’t the motor burning out so much as the circuit board. These have a simple board with a resistor or multiple that actually do the reduction in current. It’s mounted to the bottom of the Bakelite motor housing. Since the resistance is what cuts the speed, the more one runs that machine, especially if they run it with the nozzle all the way down too low, it loads that motor up. The motor itself won’t get too hot, but as it tries to draw more current that board is going to get HOT HOT HOT! I believe this was the issue, but could be wrong.
