I thought that I bring this subject to this forum.
What people think about customizing the vacuum cleaner? Do you think that it's ruining or improving the vac?
Here is what I did to my Electrolux UltraFlex Green:
I ordered the longer 2.6 meter hose, because the original 1.5 meter was too short for me.
I made powerhead wiring to it. I just needed to remove back panel from the vac and take power from the two wires coming from the cord rewind. Then I inserted the cord to exit from the front side.
Rest of the cord is connected to the hose with the removable zip ties. In the handle end cord has spiral shape what is extended type to allow free rotation of the hose.
Then there is power connectors to make possible to remove and attach the powerhead wire to it.
Powerhead wire has on/off switch to make easy to control the powerhead.
Large powerhead is from the Kärcher upright, same as the Sebo BS36. It has large brushroll with very stiff bristles and manual height position adjustment.
So why I did it?
Longer hose makes big improvement for handling the vacuum. Powerhead makes it very good deep cleaner for my large rug. When I don't need the powerhead it's easy to remove it and use other nozzles.
So in my opinion I greatly improved the vacuum, because now I can do all the vacuuming with one unit.
And why I removed the powerhead from the Kärcher upright? To be honest it doesn't have very good suction. I would say that it's mediocre. UltraFlex has clearly better suction and airflow.
So I am very happy how it came up, but it's not original anymore like many vacuum cleaner enthusiasts would like vacs to bee.
So why I did it?
