Corded Wessel Werk EBK360
floor-a-matic
somewhere
Where can I find a corded EBK360? All I found are direct connect, which is NOT the one I want. I plan to use it with my Eureka Mighty Mite 3670G
I don't think
Wessell has that model available with a cord at all. A little weird I know but oh well. Do you have a power nozzle jack on your mighty might? You could just add a pigtail to the top of the direct connect wand for a standard eureka metal end connection. Or if you don't have the jack on the canister or hose just use a 30 foot central vac hose cord.
The one I bought - though I can't remember from where - does have a cord though it's held in a clip for the "direct connect". It wouldn't be hard to un-clip it and use it with a pigtail that way. In fact, that's pretty much how I use it with my Filter Queen, except than an FQ has a pigtail coming from the hose anyway.
corded version
I actually talked with someone at Wessel Werk about this, apparently a corded version is not commonly made, but it is possible. Apparently the electrical connector on the nozzle is called a c7 or c8, it's a common electric connector in Europe. You would need to make your own cord with this connector on one end and the two prong mini connector that is typical of electric hoses on the other. Apparently there is actually a cord inside of the direct connect telescopic wand, if you could somehow open the wand and remove this cord, that would also work.
