Also, yes, if you are touching one lead to one wire and the other lead to another wire, and the meter reads less than 1 ohm, those two wires are connected... somehow.
Also also, it doesn't matter which way around you have the test leads attached to what you're checking, because continuity goes both ways... unless there's a diode, but I doubt you'll run into one.
