Compressed Air Vacuum
lux1521
Wow, the power needed for those compressed air vacuums in the link would need an air compressor MANY times more powerful than your regular home/shop compressor! Comparing 40 or 50+scfm to 4 or 5 that is a huge difference. Does not seem like an efficient way to go.
That's easy physics, you can try it for yourselves, all you need is a large plastic rubbish bag, a length of pipe (could be a vacuum cleaner hose if you wish), and your lungs.
First, put the bag onto the pipe and hold it in place with your hands, take a deep breath, press your mouth up against the pipe to seal it, and blow, note how little it inflates...
Second, repeat the same procedure, only hold the pipe a couple of inches from your mouth, and note how much more it inflates... :)
Air is drawn in as you blow down the unsealed pipe, thus you have more airflow which adds to your lung's capacity, increasing how much air will fill up the bag...
That's the basic principle as to how these air-powered vacuum cleaners work, the small amount of compressed air draws in more air which is pulled through the hose and into the bag (or in the drum in those industrial models), and the bag (or filter) traps the dirt as per normal motorised vacuum cleaners... :)
Simple, effective engineering, you can't beat it... :P
Those compressed air vacs do have some impressive suction figures-keep body parts away!Yes,I knew of one wet-dry system that needs a 50Hp compressor to run it-but you can also run it with a 3 Hp electric vacuum motor.tornado Industries.I have the electric machine-doesn't give the high suction intake figures-but moves the same CFM.These systems are used for explosive-flammable places-and hazardous wate pickup.the compressor can be located away from the vacuum cleaner work area.
