compact electra c9
Deleted member 1090
Heres the thing . My power switch on my compact is a lil
loosse the pin that holds it mooves a lil
more than it should any idea how to fix that ?
vacuum power on and off just fine
its the pin that holds the metal plate you push to
turn the vac on that mooves
any idea
reply
this is the part im talking about the pin that holds the switch u step on is a little loosse mooves side to side a lil more than it should any idea thanks
my compact electra c9 is my dayly driver so she sees alto of uses
reply
I went to canadian tire and put another pin. Its a little longer
so no chance of it getting out this time
compact is now fix and back. In oporation
good to go again . Only cost 2$ for a box of metal pin
