floor-a-matic
I gave my Compact C9 a spa day & plan to "supercharge" it.
I am replacing the original Ametek motor with a high-performance Ametek 115923 motor; & plan to put in a new PN motor.
Which PN motor should I use? It came with the original Eureka-built PN; even the lable is intact. How can I replace the PN motor without poking holes on the lable?
Thick shaft PN motor
http://www.ebay.com/itm/New-thick-s...271726663491?pt=US_Vacuum&hash=item3f442bd743
Cogged belt PN motor (Too expensive!)
http://www.ebay.com/itm/TriStar-Can...191418237283?pt=US_Vacuum&hash=item2c916a8163
A geared belt PN motor uses a cogged belt that lasts longer
Do thick shaft PN motors give higher brush roll RPMs?
I might also put in a VibraGroomer brush roller
