Classic Royal Motor and Fan Upgrades
kirbyclassiciii
Milwaukie, Oregon
Hi,
Is it possible to upgrade a Royal metal upright motor from a 3 amp one to a 6 or 7 amp one? If so, please tell me what model(s) you have in which you attempted such a conversion.
Say you have an 880 from the 1970s with a 3 amp motor. It went to 4.5 amps for 1982, and finally to 5.4 amps in 1985, and remained as such until its mid-1987 replacement by the 886, which had a 6 amp motor. Again, is it possible to upgrade a 350 watt/400 watt/3 amp motor to a 6 amp or 7 amp one?
These are the non-drop-in motors I am referring to.
History of Royal metal upright motors:
350 watts = 1946 to 1970
400 watts = 1970 to 1975
3 amps = 1975 to 1981
4.5 amps = 1982 to 1984
5.0 amps = 1987 to 1995 (654, 655, 656, 882, 885)
5.4 amps = 1985 to 1987 (last 608, 880)
6.0 amps = 1985 to 1991 (618, 360/380/660/680, 886, 6103)
7.0 amps = 1990 to 1995 (670/690, 994, 996, 9700)
In addition to general motor assembly upgrading, is it also possible to switch from the original 6-blade impeller fan (R-053004) to a 9-bladed one (R-608004 or R-608005 depending on age of unit)?
Thank you,
Ben
hey ben!
yes i had an 880 a while back and i upgraded the motor.
i do not recall what motor it was off of but i do remember it was
6 amp made it have alot more power
its fairly strait forward too.
just like the royal you will get on the 12th
its got a 6 amp in it
Royal upgrade
I know I should know this, but to you just take out the motor and swap it around? I have an old red Supreme Electro Hygene I think mdl #906?. It's too weak for me at 3 amps. Does anyone have a 5 amp motor to sell or trade?
